I am having problems with the controls on the front of my Whirlpool dishwasher. All controls are dead EXCEPT for the cancel button which when pressed cycles for 2 minutes. I know that I have power to the appliance because the cancel button works OK. Any thoughts why all other buttons would be dead and what part is needed?
Originally Posted by: Gene  This did not work. I replace the board today but still have the same problem. Other ideas?
There are two parts in question (control panel and control board) and what was good for tb69396s dishwasher does not mean a solution for everybody. Unfortunately there is no way to tell exactly which part is wrong in each case.
Originally Posted by: Gene  There are two parts in question (control panel and control board) and what was good for tb69396s dishwasher does not mean a solution for everybody. Unfortunately there is no way to tell exactly which part is wrong in each case.
Gene. What is the part number for a black control panel for GU1500XTLB3?
reply
that is the part i was looking at what is it that makes it to spen
when in use it is loose and wobbley i can:t see what makes it to spen
thanks john
thanks john John, Do not go to a different threads for the same problem. You opened the thread: http://forum.appliancepartspros...ir/45954-dishwasher.html and received the respond from Frank there. He will never know about your reply here. Go back to your original thread and keep posting your replies there. Gene.
What is John talking about?
