2 Pages12>
BobChurch
#1 Posted : Wednesday, August 26, 2009 10:34:19 AM(UTC)
BobChurch
Top burners working fine. Overnite the panel on the front lit up with: 888(where the oven temp would be)and 88:88 (where the clock/timer portion is). Looks like all the panel lights are on as well. Tried to reset and also turned the power off/on to no affect. Cannot find any direction in the troubleshooting guide I found on line. :confused:
#2 Posted : Wednesday, August 26, 2009 12:10:14 PM(UTC)
Most likely the problem is a bad Electronic Range Control. It has to be replaced together with the clock plate which has a different part number depending on its color.
- The ERC Part number: AP2633034
- The black clock plate Part number: AP2025221
- The white clock plate Part number: AP2025222
Here are the breakdown diagrams and Replacement parts for GE JSP34WW3WW | AppliancePartsPros.com
BobChurch
#3 Posted : Monday, August 31, 2009 3:02:41 PM(UTC)
BobChurch
The parts recommended to be replaced arrived today. Of course it is not an exact match to the original part. I followed the instructions step by step but now the only thing working is the oven light. Attached a couple of pics of the new part. ERC does not even light up. Which would indicate to me that no power is getting to the EC unit. Oven has power as the light works. Instructions state that the ground wire (green) does not get hooked up to the new ERC (and no place for it to do so anyway). Any direction would be greatly appreciated, getting tired of eating out and worse my wife is having way too much fun at my expense at this point.
Thanks Bob:confused:
FYI - no instruction given for the part marked malefemale, came loose ion the shipping package.
BobChurch attached the following image(s):
#4 Posted : Monday, August 31, 2009 3:35:50 PM(UTC)
As far as I remember there suppose to be "L" or "L1" terminal on the new ERC and the black wire should be connected there as well.
Can you post the instructions came with the ERC?
BobChurch
#5 Posted : Monday, August 31, 2009 4:02:33 PM(UTC)
BobChurch
Two pages of instructions attached. Stove top burners do have power.
Thanks for the assist.
BobChurch
#6 Posted : Monday, August 31, 2009 4:14:06 PM(UTC)
BobChurch
Heree's a pic of the original ERC wiring before disassembling.
#7 Posted : Monday, August 31, 2009 4:15:05 PM(UTC)
Bob,
Thank you for the instructions but I can not read them - fonts are too small and it is not possible to enlarge it without loosing quality. It might be better if you'll attach the file to the reply instead of post it in the reply body.
#8 Posted : Monday, August 31, 2009 4:16:01 PM(UTC)
Do not see them.
#9 Posted : Monday, August 31, 2009 4:18:34 PM(UTC)
Do not see them.
It was some delay with the last pics. Now it did show up.
BobChurch
#10 Posted : Monday, August 31, 2009 6:26:50 PM(UTC)
BobChurch
Trying the instructions again as an attachment this time.
Guest (12)
2 Pages12>
