The ice maker stopped making ice. There is ice in the tray, but did not eject it. The ice dispenser works, it dispenses cubes and crushed ice,but no new ice is being made. I suspect that it is the ice maker itself. does the ice maker also control the water flow into the tray?
Wha'ts the temp inside the freezer. Have you ever cleaned your condenser coil.
The temp inside the freezer is around 0 to 5 and I just cleaned the condenser coils.
if you have ice in the ice maker and the i.m. is not advaning. were are the arms of the i.m at. 2:00 7:00 10:00.
the i.m. thermostat close and will advanse the i.m. at 17 degs. you may have bad I.M. thermostat are module.
Originally Posted by: AIMANNY ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) the i.m. thermostat close and will advanse the i.m. at 17 degs. you may have bad I.M. thermostat are module. The IM is all the way down at about 5 o'clock poss. Would the refrig try to refill the tray if i empty it or does it have to go thru a full cycle?
![UserPostedImage](http://www.appliancepartspros.com/img/clear.gif) Part InfoAvailabilityPurchase enlarge photo Whirlpool icemaker kit (fits many brands) - Made by Whirlpool. This icemaker replaces most Whirlpool, Kitchen Aid and Sears Kenmore (with model prefix 106) brand icemakers. Kit includes wiring harness, mounting hardware and instructions. Use this kit when replacing an exsisting icemaker. This model does not fit refrigerators that have the ice auger assembly mounted on the door and the electronic sensor to sense ice level. Part Number: AP2984633 made by WHIRLPOOL Sale price: $96.50 Compare at: $124.87 You Save: $28.37
