MJS
#1 Posted : Thursday, January 17, 2008 10:24:17 AM(UTC)
MJS
About A Year Ago The Rinse And Hold Cycle Stoped Working, About Month Later Normal Cycle Would Not Work. Last Night The I Started It And It Was Running And About 1 Hour Later The Machine Had Stoped The Dryer Element Was Running And The Soap Did Not Open And Their Was Water In The Bottom. Help Is It Just Contol Board Or Something More Serious.
#2 Posted : Thursday, January 17, 2008 5:43:09 PM(UTC)
The first thing I would check is the dishwasher electrical connection.
Remove the bottom panel, open the junction box and verify the power cord connection to the dishwasher. The hot (black) wire must be connected to the hot wire and the neutral (white) wire must be connected to the neutral wire.
Make sure the heating element is not shorted to the ground.
Most likely the control board has to be replaced.
- The part number for the control board is AP3775998
- The part number for the heating element is AP3884745
WTW500DW1 wirlpool washer (General Talk)
by Ashley5791 2/13/2022 6:18:25 PM(UTC)
Wirlpool Centennial Washer (Washer Repair)
by 405husky 3/25/2020 8:51:06 AM(UTC)
Wirlpool 6ED22PKFXW01 (Refrigerator & Freezer Repair)
by Ady_E 1/3/2019 8:38:45 PM(UTC)
Wirlpool (Dishwasher Repair)
by taz_monster 8/6/2015 4:11:45 AM(UTC)
older Wirlpool dryer won't heat (Dryer Repair)
by automaticman 8/23/2014 4:48:43 PM(UTC)
wirlpool microwave (Microwave Repair)
by CFP 12/16/2013 5:28:13 PM(UTC)
wirlpool icemaker (Refrigerator & Freezer Repair)
by jimmy icemaker 1/30/2013 12:54:54 PM(UTC)
Wirlpool dishwasher upper arm not spinning (Dishwasher Repair)
by mogul397 12/13/2012 5:11:10 AM(UTC)
Wirlpool dishwasher will not stop cycling (Dishwasher Repair)
by dbarrett76 10/29/2012 12:02:26 PM(UTC)
wirlpool topload agitates but won't spin or pump motor hums (Washer Repair)
by curly33333 5/16/2012 6:51:35 AM(UTC)
Wirlpool Dishwasher Inlet Valve Voltage (Dishwasher Repair)
by nezoic 1/8/2012 10:05:22 AM(UTC)
my wirlpool washer wont spin (Washer Repair)
by cockroach 9/18/2011 8:26:39 PM(UTC)
Wirlpool Ultimate care II (Washer Repair)
by Peter R. 6/26/2011 1:07:57 PM(UTC)
Wirlpool Micorwave blows fuse when I press start magnetron or transformer (Oven Repair (including Ranges and Cooktops))
by wetpinkpants 10/2/2010 9:45:40 PM(UTC)
Need Wirlpool Mh3184xpy-1 tech sheet (Dishwasher Repair)
by wetpinkpants 9/30/2010 10:01:13 PM(UTC)
