I have a Bosch dishwasher that I purchased four years ago. The soap tray dispenser is not popping open during the cycle. I don't know if I need a new spring, or I need to replace the whole tray. The item # is SHU33A02UC How do I fix this?
Where do I find the model number? Is it 1150-C3
I found this forum during a search because I have the same problem: my Bosch dishwasher is about five years old. Over the past few months, the soap door sometimes was not opening. At first it was every once in a while, but has gotten worse and now it rarely opens at all. If I manually press the release it pops open and slides to the side, so I don't think the spring is the problem. Also, I can't remember the last time I had to refill the rinse aid dispenser. I used to have to fill it every few weeks, but it has been at least two months now since the "fill" message has displayed. Since the rinse aid and soap dispensers are part of the same unit, I'm wondering if this is an electrical problem.
In order to provide most accurate advise I need the complete model number of the dishwasher. Post it as a new thread, please.
I also have the same problem. My model number is SHU66C07. The door will stay shut when you close it and will release when the blue button is manually pressed. Is there any way to fix this without having to replace the entire soap dispenser?
I am having the same problem as several others with the soap dispenser. I dont mind buying another one ($56) but upon looking at it, it is not clear how to remove and replace. Can anybody be of help in this regard? Thanks, Bill
You have been a member since:: 1/8/2009(UTC) Posts: 4
My husband called Bosch. Their solution was to run Jet Dry Cleaner through the empty washer (follow directions on the bottle) at least twice.
The Jet Dry Cleaner removes hard water deposits.
I followed their instructions, bought two bottles, ran the hottest cycle twice and now my soap dispenser seems to be working.
I ran one load with the dispenser open and the other load with the dispenser closed. :)
We purchased our bosch in March and occasionally, the dispenser has wet detergent left in it. Comments on another website suggested making sure that the dispenser cup is completely dry and that nothing is blocking the door from opening or the upper wash arm from spinning. I am going to try both of these approaches but based upon this thread I am wondering whether I should be calling a technician out while it is still under warranty.
Thoughts?
It's always better to call them while the unit is still under warranty than feel sorry.
