Discuss
Bosch Detergent Dispenser
 in
Dishwasher Repair
Dishwasher runs fine, but recently the dispenser stopped opening and releasing the detergent. The release catch is sticking when you
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Bosch Detergent Dispenser
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 01-04-2008, 07:28 AM
Martinlady Martinlady is offline
Junior Member
Martinlady is on a distinguished road
Default Bosch Detergent Dispenser
Model Number: SHY66C06UC/14   Brand: Bosch   Age: 1 - 5 years
Dishwasher runs fine, but recently the dispenser stopped opening and releasing the detergent. The release catch is sticking when you try to open it manually. You can push it in, slide the entire detergent holder unit left/right, but the detergent door won't open easily.
Suggestions?
Thanks.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-04-2008, 02:35 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Most likely the detergent dispenser has to be replaced.
- The part number for the dispenser assembly is AP2834000
Good luck.
__________________
Professional appliance repair services in Orange County, California.
  #3 (permalink)
Old 01-10-2008, 05:46 PM
Junior Member
Default
Thanks, Gene. Got the part. Just want to confirm it should be a simple case of unscrewing the inside of the door to replace it. Any helpful hints to keep the frustration level down? (Other than not losing the screws? LOL!)
  #4 (permalink)
Old 01-10-2008, 06:14 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Remove six T-20 Torx screws from inner door below fascia pane.
Carefully pull bottom of outer door out from dishwasher until top door tabs clear, then pull door down until it releases from dishwasher. Take care to not scratch outer door.
Remove two plastic door guards. They can fall out when the outer door is removed.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Detergent Cup no longer locks into place GEDishwasherGuy Dishwasher Repair 0 11-20-2007 07:56 AM
water draining and detergent door Connie Dishwasher Repair 1 10-22-2007 02:46 AM
Detergent Dispener john brown Dishwasher Repair 1 10-19-2007 07:40 PM
detergent release latch linjarob Dishwasher Repair 1 10-03-2007 09:08 PM
Detergent dispenser mikewhitetx Dishwasher Repair 1 08-10-2007 09:20 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
