I got a one owner 53 fridgedaire for free on craigslist and was told it worked, but when I got it home and plugged it in it kicked on and immediately turned off. 10 minutes go by and it does it again. I can fix cars but know nothing about fridges and can't afford a repair man. Can someone help me?
If you layed it on it's side when transporting, then plugged it in right away, you just did $200 dollars worth of damage.
i brought it home on its back but i waited two weeks before plugging it in. i need some education on what to test or how to figure out what's wrong or what part to replace and where i can find it.
If your capillary line is rolled in a circle, you got oil trapped in there.
Ok so do I just take that apart and blow the oil out and then hook it back, good to go? Or is that a freon line?
That capillary line needs to be cut after refrigerant is evacuated, then blown out with nitrogen gas, then re-sealed, not a job for a novice.
So do all you guys think that's what is causing it to try to start and immediately quit and repeat that every 10 minutes? If so, how much should I expect to pay for that?
Maybe varnish buildup on the compressor innerds, maybe was bad when you got it. It may have allways had damaged windings. Dunno whithout looking. I have seen compressors function fine into a clogged capillary.
