flame shuts off after a couple of minutes
Does it come back on?
only when I turn off dryer then start it again. I'll have to excuse me first time here on the website
Originally Posted by: Gene ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Does it come back on?
Gene. I check it today and actually the flame does come back on then turns off in about one minute then keeps doing the same on and off
If not the coils then the problem can be restricted air flow through the dryer air ducts and/or vent line.
where is the gas valve coil located? what tools will I need?
They are located on top of the gas valve. You have to remove the front panel to access them. No special tools needed.
Dear Gene, I'm a little confused still, the part number you gave me was different than the part order # when I clicked on the website. So, do I have to replace all 3 coils?
Originally Posted by: yahshua ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Dear Gene, I'm a little confused still, the part number you gave me was different than the part order # when I clicked on the website. So, do I have to replace all 3 coils? thanks for the help:) [ /quote]
