carvelli
#1 Posted : Thursday, August 20, 2009 10:41:11 AM(UTC)
carvelli
My Frezzer Is Freezin But Refer Warm I Unplugged Over Night Got Air Flow Back To Refer But Freezer Is Icing Up Again
magician59
#2 Posted : Thursday, August 20, 2009 10:53:02 AM(UTC)
magician59
Sounds like you have a defrost malfunction.
carvelli
#3 Posted : Thursday, August 20, 2009 10:54:59 AM(UTC)
carvelli
Why Are Freezer Coils Freezing Up
carvelli
#4 Posted : Thursday, August 20, 2009 10:58:45 AM(UTC)
carvelli
I CHECK VOLTAGES ON DEFROST BOARD NO VOLTAGE ON DEFROST TERM TERMINAL BUT DID AN OHM READING SAYS IT CLOSED SO I SHOULD GET 120 RIGHT?
magician59
#5 Posted : Thursday, August 20, 2009 12:02:48 PM(UTC)
magician59
Can you force a defrost? If not, then wait 'til it goes into defrost on its own, and see if the defrost heater comes on. (you should know in a matter of seconds, as you'll feel the heat and hear the "sizzle" of melting ice. If no heat, either the heater element is open, or the defrost thermostat is open. Generally, we replace them as a pair.
carvelli
#6 Posted : Monday, August 24, 2009 5:49:19 PM(UTC)
carvelli
how do you force a defrost? i ordered one of those boards that is located in refer light harness. it controls the defrost cycles local refer tech's suggestion. i was told element or term usually dont go bad
magician59
#7 Posted : Tuesday, August 25, 2009 6:04:58 AM(UTC)
magician59
Elements and thermostats DO go bad. That's why we test them to isolate the problem--BEFORE committing to the higher cost of a control board.
