Stads
#1 Posted : Tuesday, January 15, 2008 5:02:30 PM(UTC)
Stads
My washer stopped after filling. On agitate cycle, I here and feel buzzing from around the timer switch. I have moved the switch to different positions, washer will fill but not advance. Just a buzzing from the timer. I have read many posts and it seems that the timer is the last thing to go. I do not want to waste my time and money for the wrong part. What do you think?
Thanks,:confused:
#2 Posted : Wednesday, January 16, 2008 2:59:08 PM(UTC)
Did it drain and/or spin?
Did the motor make any noise at any timer position?
Stads
#3 Posted : Wednesday, January 16, 2008 3:26:55 PM(UTC)
Stads
The motor didn't make any sounds. Would not drain or spin. Just fill.
#4 Posted : Wednesday, January 16, 2008 3:42:25 PM(UTC)
Most likely the problem is a bad lid switch.
- The part number for the lid switch is AP3180933
