2 Pages<12
boomerang6297
#11 Posted : Wednesday, August 19, 2009 1:45:01 PM(UTC)
boomerang6297
i just replaced the thermal fuse because when i bypassed it the dryer started working.i noticed the heating element glowed cherry red and it did not do that when i had the problem.i think it heated,but not as hot as it is now.one concern is ...i see the heating element does not get red all the way around..only about two thirds around.does that mean the element is broken and should be replaced?:cool:
#12 Posted : Wednesday, August 19, 2009 1:51:03 PM(UTC)
It's hard to say without seeing the heating element. You have to pull it out and inspect the coils.
boomerang6297
#13 Posted : Wednesday, August 19, 2009 2:11:26 PM(UTC)
boomerang6297
thanks for the reply.does that get pulled out from the front (whirlpool WES9200SQ0)?thanks:)
#14 Posted : Wednesday, August 19, 2009 10:30:54 PM(UTC)
You probably can access it by removing the toe panel.
boomerang6297
#15 Posted : Thursday, August 20, 2009 4:46:43 AM(UTC)
boomerang6297
thanks for all the help!!:)
#16 Posted : Thursday, August 20, 2009 11:15:12 AM(UTC)
magician59
#17 Posted : Thursday, August 20, 2009 11:53:16 AM(UTC)
magician59
Originally Posted by: kayakcrzy Go to Quoted Post
replace the thermister then. It is in the back and has two wires coming to it. Tom
The thermistor's on the blower housing, in the front of the dryer.
Guest (8)
2 Pages<12
