semperfimom1985
#1 Posted : Tuesday, August 18, 2009 6:38:29 PM(UTC)
semperfimom1985
My Amana (modelsrd2555w) side by side fridge recently frosted up. I've had this happen before so I replaced the defrost thermostat. Here's where I'm stumped it the fan runs at first a and cuts off never cutting back on. The coils frost up but not as bad as when the defrost thermostat is out. The bottom of the freezer is cold but it's not cold enough to make ice. I'm thinking it's the fan motor but I'm not sure. I don't know how to tell if new defrost thermostat is bad or if it's just the fan. What do I do?
Wendy
#2 Posted : Wednesday, August 19, 2009 2:52:52 AM(UTC)
I would pull the evaporator motor and plug it in the wall outlet to see if it runs. Post results.Make sure it is labled 115 volts.
semperfimom1985
#3 Posted : Wednesday, August 19, 2009 9:53:47 AM(UTC)
semperfimom1985
The fan I'm referring to is the internal fan above the coils on the inside of the freezer. It isn't made too plug into the wall.
#4 Posted : Wednesday, August 19, 2009 12:49:59 PM(UTC)
You can use a "cheater cord" with spade terminals that will plug into the motor.
