Casego
#1 Posted : Monday, August 17, 2009 2:43:19 PM(UTC)
Casego
I have an Inglis electric dryer and can only get low heat out of it. The heating element comes on but only for a short time. Does this indicate that the cycling thermostat needs to be replaced?
sidfink43
#2 Posted : Wednesday, August 19, 2009 9:10:26 AM(UTC)
sidfink43
That sounds like a likely candidate. Unfortunately you will have to replace it to determine if it is the problem.
Good luck,
