I have an Inglis electric dryer and can only get low heat out of it. The heating element comes on but only for a short time. Does this indicate that the cycling thermostat needs to be replaced?
That sounds like a likely candidate. Unfortunately you will have to replace it to determine if it is the problem.
Good luck,
