RHUTCH
#1 Posted : Monday, August 17, 2009 2:57:11 PM(UTC)
RHUTCH
My Whirlpool washer fills up and goes through the wash cycle and then stops completly. It wont drain or anything after the wash cycle. Put a new timmer switch in it and still does same thing. Is there a relay or soliniod some where that might be bad?
RHUTCH
#2 Posted : Tuesday, August 18, 2009 4:25:31 PM(UTC)
RHUTCH
Found my problem! The lid switch mounting tabs were broken, switch it self works but the tabs were not holding it up tite to the top. So when the lid was closed the whole switch would move and not make contact. LOL
topload washer will not drain or spin (Washer Repair)
by olac757@gmail.com 8/9/2013 9:08:21 PM(UTC)
Washer will not drain or spin (Washer Repair)
by Fixit Dad 5/23/2013 4:26:49 PM(UTC)
Washer will not drain or spin, new pump and lid switch (Washer Repair)
by tangerine30680 1/26/2013 12:42:38 PM(UTC)
I replaced lid switch, still washer will not drain or spin (Washer Repair)
by dnschrstn 11/12/2012 12:39:16 PM(UTC)
Maytag Washer Will Not Drain or Spin during White or Color Cycle (Washer Repair)
by ametz69 11/6/2012 5:52:41 PM(UTC)
by apprik 6/20/2012 5:39:48 AM(UTC)
Top loan washer will not drain or spin (Washer Repair)
by Tom Roberts 4/26/2012 9:03:03 AM(UTC)
LG washer will not drain or spin (Washer Repair)
by rangers02 10/12/2011 2:51:22 PM(UTC)
Roper washer will not drain or spin? (Washer Repair)
by Burns5150 9/3/2011 6:50:17 AM(UTC)
Washer will not drain or spin on final rinse. (Washer Repair)
by link888 3/24/2011 7:38:52 AM(UTC)
by link888 3/24/2011 7:32:23 AM(UTC)
Washer will not drain or spin. (Washer Repair)
by albouldin 12/3/2010 9:21:23 AM(UTC)
Whirlpool washer will not drain or spin. Is it the lid switch? (Washer Repair)
by conramana 6/10/2009 7:48:12 PM(UTC)
whirlpool washer will not drain or spin (Washer Repair)
by llbishop7@cs.com 5/4/2009 8:47:22 AM(UTC)
Washer will not drain or spin when loaded (Washer Repair)
by Roc1966 12/11/2008 3:37:57 AM(UTC)
