ralp
#1 Posted : Monday, August 17, 2009 7:22:21 AM(UTC)
ralp
the igniter glows ,,but the oven will not lite ..could my regular vave be defective
#2 Posted : Monday, August 17, 2009 1:40:39 PM(UTC)
Very likely the problem is a bad (weak) igniter even if it does glow. The best thing is to check the current drawn by the igniter. If it is 3.2 amps or less then this is the culprit.
Guessing is not a best way to diagnose a problem and it can make repair much more expensive than it suppose to be.
- The oven igniter Part number: AP2150412
oven will not lite (Oven Repair (including Ranges and Cooktops))
by Rick2112 11/18/2013 6:49:53 PM(UTC)
Thermador PGR364GL Oven will not lite (Oven Repair (including Ranges and Cooktops))
by PaulKru 5/15/2012 9:34:55 AM(UTC)
by Jim E 2/26/2009 4:13:32 PM(UTC)
by schautz86 2/10/2008 11:03:36 AM(UTC)
