onthefritz
#1 Posted : Monday, August 17, 2009 9:25:27 AM(UTC)
onthefritz
My refridgerator seems to be turning itself off. I noticed things were not very cold and that things were defrosting in the freezer. I then turned it up and it would get colder and the items would freeze again, and then the cycle just keeps repeating itself. Help!
#2 Posted : Monday, August 17, 2009 11:34:11 AM(UTC)
Pull the refrigerator out of the wall, remove the rear cover and clean the condenser. Make sure the fan motor next to the compressor works fine.
onthefritz
#3 Posted : Monday, August 24, 2009 3:33:37 PM(UTC)
onthefritz
Gene,
Thank you very much for your reply. I did as you suggested, however, all the dust and everything was actually behind the grid that is located on the front the refridge. Anyway, it appeared to be better for a day or so, but then it just started acting the same way as before. I had begun to read some of your other posts, came up with a possible conclusion that it maybe wasn't anything that had to do with the defrost cycle, no frost build up on the back on the freezer wall. Any thoughts?
Teresa
#4 Posted : Monday, August 24, 2009 3:36:38 PM(UTC)
Teresa,
Have you checked the fan motor next to the compressor?
onthefritz
#5 Posted : Monday, August 24, 2009 3:41:12 PM(UTC)
onthefritz
Teresa,
yes, I did take the back panal off, the fan was moving rather quickly--
Teresa
onthefritz
#6 Posted : Friday, August 28, 2009 9:31:16 AM(UTC)
onthefritz
Gene,
I was wondering if you had anymore suggestions about the fridge--the fan next to the compressor is running.
Thanks Teresa
#7 Posted : Friday, August 28, 2009 11:05:41 PM(UTC)
Remove the rear panel in the freezer and check how the evaporator is covered with snow. If it's not 100% covered with thin snow then it can be a problem with the sealed system.
Guest (4)
