Redfish
#1 Posted : Friday, August 14, 2009 10:42:15 AM(UTC)
Redfish
My dryer has been heating up off and on through any off the cycles. The timer appears to be working fine. Any ideas?
Redfish
#2 Posted : Friday, August 14, 2009 12:35:07 PM(UTC)
Redfish
I have checked the following:
1. Thermal fuse
2. Cycling thermostat
3. Igniter
4. Flame sensor
All of them are closed.
I checked both gas valve coils and the one with three terminals is giving me an open reading across two terminals.
Do I simply replace the the one gas valve coil or should I replace both of them?
Thanks.
#3 Posted : Friday, August 14, 2009 1:26:12 PM(UTC)
It's better to replace both coils for two reasons:
1. It makes the repair more reliable
2. You will save $$$
- The coil kit Part number: AP3094251
