I was linked to this site thru another with part of the answer I was looking for. This one so far is much more help.
The dryer does not heat. The element does not glow either. I checked the continuity of the flame sensor and it is good. Am I to assume then that the heating element is bad? Or could there be another issue?
Found answer in another post. The thermal fuse is bad. i will replace along with the cycling thermostat and see what happens.
Post the results, please.
That fixed it.
The wife is happy.
Thanks for the help. Great website.
Until next time.
I'm glad you were able to fix it.
