Brian K
#1 Posted : Thursday, January 3, 2008 6:23:17 PM(UTC)
Brian K
I was linked to this site thru another with part of the answer I was looking for. This one so far is much more help.
The dryer does not heat. The element does not glow either. I checked the continuity of the flame sensor and it is good. Am I to assume then that the heating element is bad? Or could there be another issue?
Found answer in another post. The thermal fuse is bad. i will replace along with the cycling thermostat and see what happens.
#2 Posted : Friday, January 4, 2008 1:11:06 PM(UTC)
Post the results, please.
Brian K
#3 Posted : Saturday, January 12, 2008 6:20:47 PM(UTC)
Brian K
That fixed it.
The wife is happy.
Thanks for the help. Great website.
Until next time.
#4 Posted : Tuesday, January 15, 2008 10:33:23 AM(UTC)
I'm glad you were able to fix it.
