Update : The entire model # is 790.46609500 Thanks! None of my control panal buttons work. Error code F30 displays whenever I touch the control pad. My husband said that this first happened when he was boiling water for blanching beans. He had the water boiling for an hour. The burners work fine-they have nobs to turn on and off. The warming burner that works with a touch button does nothing. Sears to charge $129 for minimum labor plus parts and service call. I don't know what to do.:( Melissa
Hi Melissa,
The "F30" error code means "Open probe connection.". In order to provide more accurate advice we need the complete model number of the range. The model number you posted is incomplete. Verify and repost it.
The entire model number is 790.46609500 Thanks,Melissa Originally Posted by: Gene  Hi Melissa,
