I have a whilrpool gold accubake oven. The stove works. But the bake, convection bake, broil and timer won't go on. I can change the time and the clock works. I press the buttons but nothing happens. I fiddled with the elements and they are fine, the control lock is off and there is not a delay start. Any ideas? I have had it only 5 years!
What is the complete model number of the oven?
Hi Gene,
the model number is YGY398LXPQ00.
The first thing I would do is pull the range out of the wall, remove the back panel and check the thermal cut-out (#23 on the break down diagram) for continuity. Replace if it's open. Here are the break down diagrams for the Whirlpool range Model YGY398LXPQ00Gene.
