2 Pages12>
Ronrurban
#1 Posted : Thursday, January 10, 2008 8:56:06 AM(UTC)
Ronrurban
Have a Whirlpool Gold Super capacity 465 accubake.
The temp jumps around - high and low when baking. As much as 50 degrees up or down. The digital board read 375 and actual over temp will be off. Help!! This makes it very hard to bake anything.
Thanks Ron
#2 Posted : Thursday, January 10, 2008 5:51:55 PM(UTC)
Hi Ron,
In order to provide the most accurate advise I need the complete model number of the unit.
Ronrurban
#3 Posted : Friday, January 11, 2008 7:12:06 AM(UTC)
Ronrurban
Hi Gene, the part number on the inside of the door is 3196685 rev.rel.
Is this the number you need? I do not have a owners manual.
Thanks!
Ron
#4 Posted : Friday, January 11, 2008 10:19:02 AM(UTC)
You can find the model number on the frame behind the bottom drawer.
Ronrurban
#5 Posted : Friday, January 11, 2008 10:21:39 AM(UTC)
Ronrurban
Thanks Gene, I will get it this weekend and send on Monday. Have a great weekend.
Ron
Ronrurban
#6 Posted : Monday, January 14, 2008 7:41:54 AM(UTC)
Ronrurban
Hi Gene, the model# is GS395legq - serial#rk3710128
Thanks!
Ron
#7 Posted : Monday, January 14, 2008 4:59:19 PM(UTC)
Hi Ron,
The first thing I would do is check the oven sensor (#12 on the chassis break down diagram) resistance at the control board.
It suppose to be about 1100 Ohms at the room temperature.
If it's wrong then replace the oven sensor.
If there is nothing wrong, then replace the control board.
In order to help you with the right part numbers I need you to post the color of the unit and one more digit after "Q" in the model number.
Ronrurban
#8 Posted : Tuesday, January 15, 2008 6:39:43 AM(UTC)
Ronrurban
Thanks Gene, The unit is white and there is a 6 after the Q. I will let you know what I find whith the ohm reading.
Ron
#9 Posted : Tuesday, January 15, 2008 8:40:21 AM(UTC)
Hi Ron,
- The part number for the oven temperature sensor is AP3130719
- The part number for the control board is AP2990342
Here are the break down diagrams for the Whirlpool range Model GS395LEGQ6
Ronrurban
#10 Posted : Tuesday, January 15, 2008 9:01:38 AM(UTC)
Ronrurban
Thanks Gene, would I access the the sensor connection from the back of the control panel?
Ron
Guest (7)
GE Monogram Fluctuating Temps (Refrigerator & Freezer Repair)
by BarryG 8/7/2014 1:06:15 PM(UTC)
Fluctuating temp for bottom freezer (Refrigerator & Freezer Repair)
by Fxitpop 8/24/2013 10:54:35 AM(UTC)
GE Profile refrigerator, fluctuating temperatures....... (Refrigerator & Freezer Repair)
by FDAR 7/14/2011 4:02:59 PM(UTC)
fluctuating temperatures (Refrigerator & Freezer Repair)
by yeller1 4/26/2011 2:16:40 PM(UTC)
2 Pages12>
