Yes Ron, you were right.
Hi Gene, I fianally got a ohm meter and the reading was 1079. Does this mean that the control panel needs to be replaced? If so, can you give part #? Thanks! Ron
Originally Posted by: Gene  Hi Ron, - The part number for the oven temperature sensor is AP3130719 - The part number for the control board is AP2990342 Here are the break down diagrams for the Whirlpool range Model GS395LEGQ6Gene. Good luck. Gene.
Thanks Gene, just to clarify, if the sensor reading is 1079 ohms should I only order the control board? Thanks Ron
Yes Ron,
The sensor reading is good.
Hi Gene, I wanted to thank you for your help! I replaced the control panel and all is right with the world. My fiancee can now use her oven again. Thanks again Ron
Hi Ron,
I'm glad you were able to fix it.
