After fishing out the spoon that my son dropped into the disposal the sound of grinding metal has not stopped. I felt around the inside of the disposal and cannot find any foreign materials. What next?
Rank: Administration
Groups: Joined: 7/18/2007(UTC) Posts: 799
With the power to the disposer turned off, see if the blade is loose. Unfortunately, we do not carry parts for Insinkerator brand, so I wouldn't be able to help you there. I found a breakdown diagram for Badger 5 and a place where you may possibly get replacement parts from if needed (we haven't dealt with them, so "buy at your own risk"). Hopefully, you could just tighten the blade a little. Diagram:  Site: Insinkerator Badger 5 Parts from FAMOUS PLUMBING SUPPLYHope this helps.
