Kaye
#1 Posted : Monday, January 14, 2008 6:06:57 AM(UTC)
Kaye
I did not shut my upright freezer door completely & the compressor ran for a long time. :eek: After cleaning up the mess, I cannot get the freezer to run. Interior light is on. I tried turning the defrost timer to "click" & waited. Results; nothing happened. Compressor will not come on. Any suggestions on where to start troubleshooting & how would be greatly appreciated. Thank-you,
Kaye
#2 Posted : Monday, January 14, 2008 4:26:44 PM(UTC)
Did it try to start or it's completely dead?
Did it make any noises?
Kaye
#3 Posted : Monday, January 14, 2008 6:59:06 PM(UTC)
Kaye
Unfortunately, Gene, it is like road-kill dead. After I reset the defrost timer,"click", it makes no sounds at all. No attempts to start, no hums, no nothing. Appreciate any ideas or suggestions.
Thank-you,
Kaye
#4 Posted : Monday, January 14, 2008 7:05:05 PM(UTC)
Are you sure the defrost timer is in the cooling mode and the cold control is "on"?
Sounds like there is no power to the compressor.
Kaye
#5 Posted : Monday, January 14, 2008 7:15:37 PM(UTC)
Kaye
Thanks. Cold control is "on' , set at 5.
I turn the defrost timer until it "clicks" ;wait 1 hour, nothing. I turn the defrost timer to "click"; wait until the next morning; again nothing.
Does the defrost timer control the power to the compressor?
#6 Posted : Tuesday, January 15, 2008 2:48:42 AM(UTC)
Remove the cold control and short the wires to see if it will run and post results.
Kaye
#7 Posted : Tuesday, January 15, 2008 8:37:31 AM(UTC)
Kaye
Removed cover of cold control and VOILA !!! The red wire had separated from the connector. Replaced a 25 cent connector and firmly crimped the wire. Reconnected and everything is working fine. Thanks for the advice & guidance. :)
If you live in the State College, PA or Orange Cty., California area, I would highly recommend richappy or Gene for any of your appliance repair needs.
Thanks again guys. You are the greatest!!!
Kaye
#8 Posted : Tuesday, January 15, 2008 8:43:36 AM(UTC)
We're glad you were able to fix it.
