KPfromIowa
#1 Posted : Tuesday, August 11, 2009 9:50:44 AM(UTC)
KPfromIowa
Shut dryer door, turned on, hit START button and it clicks once and goes to "SENSING" light but does not rotate or start? Nothing? All the lights are on, but no action???
#2 Posted : Tuesday, August 11, 2009 12:55:25 PM(UTC)
What is the complete model number of the dryer?
KPfromIowa
#3 Posted : Tuesday, August 11, 2009 1:07:33 PM(UTC)
KPfromIowa
:confused: It is GEW9200 LWO
Does that tell you anything??? I HOPE?????
#4 Posted : Tuesday, August 11, 2009 6:40:43 PM(UTC)
Perform the diagnostic as described in the Tech sheet and post the results.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL GEW9200LW0 | AppliancePartsPros.com
Mooresville78
#5 Posted : Thursday, February 25, 2010 7:56:38 PM(UTC)
Mooresville78
I am having same problem even diagnostic's still nothing.
#6 Posted : Friday, February 26, 2010 2:29:29 PM(UTC)
You posted the question in the wrong thread. Your dryer is Cabrio, not Duet. Answered here: http://forum.appliancepartspros...-sensing.html#post193555
the viking
#7 Posted : Sunday, June 27, 2010 5:01:10 PM(UTC)
the viking
Gene,
I was impressed with your response and have printed out the Duet Dryer diagnostic manual. I will run through the checklist and see if it results in anything. We have had the dryer and have used it for 5 years lightly.
One thought - there are pipes above that occassionally drip condensation onto the top of the machine. I am wondering if moisture could seep into the joint between the face unit and the housing and affect it from turning on. Just as a precaution I am going to seal this with some tape and put a towel on top.
I am hoping something happens here, as my husband is out of work and the tech that stopped by quoted us $500. for a new motherboard of sorts.
the viking
Whirlpool Duet Dryer clicks, but does not turn on (Dryer Repair)
by MariP 6/22/2015 8:48:05 AM(UTC)
