Selah 1
#1 Posted : Friday, August 7, 2009 7:56:49 AM(UTC)
Selah 1
My Kenmore electric dryer quit during the cycle, repush the button and it starts but srops when you let go of the start button. Hold the button down or prop somthing against the button and it runs the cycle. Ordered a new button switch and put it in and it does the same thing. Dryer runs just fine and cycles as long as button is pused in. Could the new button be faulty or is there something else wrong. Thanks
magician59
#2 Posted : Friday, August 7, 2009 10:37:38 AM(UTC)
magician59
What's the model number?
Selah 1
#3 Posted : Friday, August 7, 2009 5:29:42 PM(UTC)
Selah 1
model # is, 110.66652501 Type DWJR-ELE-2406028-FM54
Thanks for any help!!!
magician59
#4 Posted : Saturday, August 8, 2009 6:22:23 AM(UTC)
magician59
I couldn't find a match to the model number you posted; But the problem you describe suggests the start button is good. There is a relay that is bad. It is either a separate part, inside the console, or it is on a circuit board, also inside the console. If it is on a board, the entire board needs to be replaced.
Selah 1
#5 Posted : Saturday, August 8, 2009 12:06:14 PM(UTC)
Selah 1
Thanks for the info on the relay, I'll check it out later and let you know what I find, sun is out so need to ride the H-D the rest of the day.
Dryer start button won't actvate (Dryer Repair)
by Cpilkington 5/14/2015 6:50:07 AM(UTC)
electric dryer start button does not start the dryer (Dryer Repair)
by ddelay 4/20/2012 5:27:18 PM(UTC)
Amana Dryer Start Button Buzzing and won't start (Dryer Repair)
by rebeccahotsun154 12/16/2011 3:26:29 PM(UTC)
Dryer start button problem & dryer shuts off before dry (Dryer Repair)
by tunesmithtn 10/20/2011 12:27:59 PM(UTC)
Dryer start button not working (Dryer Repair)
by mohr8271 4/3/2011 1:21:18 PM(UTC)
by mohr8271 4/3/2011 1:20:37 PM(UTC)
Whirlpool electric dryer start button clicks but motor do not run (Dryer Repair)
by Kash123 9/25/2010 11:39:54 PM(UTC)
push dryer start button...boom! (Dryer Repair)
by zanebo1 5/29/2010 3:53:42 PM(UTC)
dryer start button noise - dryer won't run (Dryer Repair)
by brhodes58 3/10/2009 5:42:12 AM(UTC)
Dryer Start button broke off when turning knob (Dryer Repair)
by debandchazmo@aol.com 1/26/2009 8:12:40 AM(UTC)
Dryer start button (Dryer Repair)
by Yorba 8/13/2007 10:00:49 AM(UTC)
