xfeejayx
#1 Posted : Monday, August 3, 2009 9:32:48 AM(UTC)
xfeejayx
I think I have a faulty 'switch flood asm'
part 308 Replacement parts for GE EDW4060G02SS | AppliancePartsPros.com
how can I make sure this part is the culprit? Thanks in advance for any help
misterfixall
#2 Posted : Monday, August 3, 2009 8:22:06 PM(UTC)
misterfixall
what are you experiencing?
xfeejayx
#3 Posted : Tuesday, August 4, 2009 2:44:32 AM(UTC)
xfeejayx
everything functions, except that it does not pump water into the tub. i checked the float switch, moved it up and down, seems to move fine. i put water in it manually and ran it and seemed to cycle fine.
#4 Posted : Tuesday, August 4, 2009 3:06:15 AM(UTC)
If your float switch makes a clicking noise, it's probably ok. Most of the time it's a bad control module AP3794574, clogged water solenoid, or bad water supply. Without a meter, you can feal the solenoid to see if it's vibrating, if so, you probably have a clogged screen in the solenoid.Part # AP2039343. If not, you will need a meter to verify a bad control module.
