craigjung
#1 Posted : Monday, January 7, 2008 9:58:56 AM(UTC)
craigjung
Hello,
My wife used the oven to bake a cake on Friday. After it preheated, she inserted the cake and walked away. 21 minutes (per the oven clock) after inserting the cake she smelled burning from the kitchen. The display still said 350 degrees, but when she opened the oven door, it was extremely hot and the cake and pan were burnt. She took the cake out and as she was putting the burnt cake on the counter, she heard a beep-beep-beep. She looked and it had an error message which quickly disappeared and then the message said cool down-locked....although the door never locked.
The next day, she used the oven again, but stayed near it to see if the problem occured again. The same thing happened. The oven seems to go into the self-clean mode while it still reads the temperature which was originally set. Unfortunately, my the error codes came and went too quickly for her to see what they were. Thanks, Craig Jung
#2 Posted : Monday, January 7, 2008 10:56:36 AM(UTC)
Rank:: Advanced Member
Hi Craig,
Most likely the problem is a bad control board.
- The part number for the control board (white face) is AP2990013
- The part number for the control board (black face) is AP2990015
- The part number for the control board (almond face) is AP2990014
- Here are the break down diagrams for the Whirlpool range Model GS395LEGQ0
Good luck.
craigjung
#3 Posted : Tuesday, January 8, 2008 4:43:50 AM(UTC)
craigjung
Hi Craig,
Good luck.
Thanks Gene, what is the difference between GS395LEGQ0 and GS395LEGQ1 THRU GS395LEGQ5? Thanks, Craig
#4 Posted : Tuesday, January 8, 2008 8:11:26 AM(UTC)
Craig,
What is the complete model number of your range?
craigjung
#5 Posted : Tuesday, January 8, 2008 9:40:47 AM(UTC)
craigjung
Gene,
It's GS395LEGQ then several spaces followed by a 7
Thanks,
Craig
#6 Posted : Tuesday, January 8, 2008 9:59:54 AM(UTC)
Craig,
The right part numbers are:
White face - AP2990342
Black face - AP2990403
Biscuit face - AP2990345
craigjung
#7 Posted : Thursday, January 10, 2008 6:35:59 AM(UTC)
craigjung
Thanks Gene for the info. Since it is a costly part, and before I order the part from you, could there be any other possible cause for this problem. Also, are directions included with the part you mentioned? Thanks Again, Craig
#8 Posted : Thursday, January 10, 2008 8:25:23 AM(UTC)
I do not think anything else could cause it.
Let me know when you will get the part and I'll help you with instructions.
Best regards,
craigjung
#9 Posted : Thursday, January 10, 2008 1:16:58 PM(UTC)
craigjung
Best regards,
Hi Gene, I've ordered the pare and will contact you when it arrives. Thanks Again, Craig
Need help narrow down oven problem (Oven Repair (including Ranges and Cooktops))
by Guest 7/4/2022 6:46:54 PM(UTC)
Thermador PG304BS/09 Oven Problem (Oven Repair (including Ranges and Cooktops))
by Guest 8/15/2021 7:27:03 PM(UTC)
Range oven problems. (Oven Repair (including Ranges and Cooktops))
by jorge osorio 1/29/2019 1:16:21 PM(UTC)
Oven Problem - lower, no heat; upper A-OK (Oven Repair (including Ranges and Cooktops))
by gesche444 9/15/2017 12:21:36 PM(UTC)
Oven problem (Oven Repair (including Ranges and Cooktops))
by Lhodges 1/28/2017 10:58:04 PM(UTC)
Kitchen Aid oven problem (Oven Repair (including Ranges and Cooktops))
by Rawger11 9/2/2014 11:13:56 AM(UTC)
Maytab oven problem (Oven Repair (including Ranges and Cooktops))
by DJ5140 3/16/2014 8:43:29 AM(UTC)
Whirpool Oven Problems (Oven Repair (including Ranges and Cooktops))
by phsffaman 2/15/2014 6:35:40 PM(UTC)
Oven problem during self clean cycle (Oven Repair (including Ranges and Cooktops))
by cgoetzfried@att.net 1/21/2014 5:48:07 PM(UTC)
kitchenaid oven problem (Oven Repair (including Ranges and Cooktops))
by ticat900 11/25/2013 11:06:28 AM(UTC)
Range/oven Problem (Oven Repair (including Ranges and Cooktops))
by slongo 10/22/2013 5:06:51 AM(UTC)
GE Profile Oven Problems (Oven Repair (including Ranges and Cooktops))
by RSF 10/16/2013 10:23:15 PM(UTC)
by Whizknot 10/7/2013 7:31:01 PM(UTC)
self cleaning oven problem (Oven Repair (including Ranges and Cooktops))
by preachergirl09 9/8/2013 11:20:21 AM(UTC)
wall oven problems (Oven Repair (including Ranges and Cooktops))
by jethro75 8/1/2013 6:35:09 AM(UTC)
