King1950
#1 Posted : Friday, July 31, 2009 8:17:03 PM(UTC)
King1950
First,...machine will not run now....it makes a motor humming type sound. We are thinking that the pump is locked up and the belt is showing wear.
So, first....should we replace the pump,...is it possible something got down in the pump and locked it up. That would explain the noise and why it won't start, and why motor noise...because motor turns but belt doesn't...we think. So....there's the Aeeeeaaeee sound like the motor is one...but nothing will turn or go on.
How do you take off the front panel? There are two clips on the bottom that hold the panel on,...but we can't figure out how to get them off without damaging the panel.
What would you suggest doing?
King1950
#2 Posted : Saturday, August 1, 2009 12:38:32 PM(UTC)
King1950
Have a washer that is a maytag its model number is may7057a serial number is 10574482wz , need to know how to get apart front panel to get to pump , think something is in pump , making noise. thank you . :)
magician59
#3 Posted : Saturday, August 1, 2009 4:12:07 PM(UTC)
magician59
Using a putty knife, or a similar tool, depress the spring clips at the top corners of the front panel, while lifting the top away at the same time. Inside the front panel, you'll find a 5/16 inch hex drive screw at each top corner. Remove them abd the panel will then rock off the clips you see at the bottom.
