hosman
#1 Posted : Wednesday, July 29, 2009 11:54:19 AM(UTC)
hosman
I went to defrost the freezer and simply turned the inside nob to off. after the whole process i turned the nob back to the setting of 5 and left it till the next day.i can not get the thing to start freezing again.what am i missing?
#2 Posted : Wednesday, July 29, 2009 1:45:19 PM(UTC)
If it does not make any noises and not cooling then most likely the problem is a bad temperature control.
- The temperature control Part number: AP2113041
