bernie M
#1 Posted : Saturday, July 25, 2009 6:01:51 PM(UTC)
bernie M
Washer leaks from the drain hose under the washer
sidfink43
#2 Posted : Monday, July 27, 2009 6:05:42 AM(UTC)
sidfink43
Hi Bernie
Take off the cabinet and confirm the source of the leak. This site will show you how to do that.
Kenmore top loader blues ‎(SublimeMasterJW's Appliance Advice)‎
It might be the pump, an easy replacement. If not, replace the hose.
Good luck
bernie M
#3 Posted : Monday, July 27, 2009 6:19:04 AM(UTC)
bernie M
It was the hose underneath that goes from the pump to the drain. THANKS
Roper Washer Leaks, AT MY WITS END!!! (Washer Repair)
by Timm777 2/11/2012 3:39:45 PM(UTC)
