2 Pages12>
jam
#1 Posted : Monday, January 7, 2008 9:47:07 AM(UTC)
jam
No water flowing to ice tray. The ice maker works when I put water in the tray. Water dispenser in door works. Where do I begin to check for freezing in the line? Most of the tubing is covered. Do I have to pull the refridgerator away from the wall? Is the water valve for the ice maker in the back? I would love to have a diagram of the parts and their loactions.
#2 Posted : Monday, January 7, 2008 11:15:29 AM(UTC)
Open the freezer door and view the "status" LED on the right side.
Press in the emitter flapper door on the left side to unblock the optics beam and view the "status" LED.
Post you findings.
jam
#3 Posted : Tuesday, January 8, 2008 7:49:01 AM(UTC)
jam
The red light is on continuously.
#4 Posted : Tuesday, January 8, 2008 10:07:16 AM(UTC)
Next step:
Remove the ice maker and check the water feeding tube for freezing.
If it's frozen, defrost it using a hair dryer.
If it's frozen, then the water inlet valve has to be replaced.
- The part number for the water inlet valve is AP3160649
tmagolas@rogers.com
#5 Posted : Tuesday, February 21, 2012 1:09:11 PM(UTC)
tmagolas@rogers.com
i HAVE THE SAME PROBLEM WITH MY KITCHEN AID KSRS25ILSS03,
WHERE DO I FIND THE WATER INLET VALVE ON MY MODEL? COULD YOU PLEASE GIVE ME A PART#.
THANKS
#6 Posted : Tuesday, February 21, 2012 3:30:49 PM(UTC)
The water inlet valve is located on the back of the refrigerator. You should see the water line connected to this valve.
- The water inlet valve Part number: AP5263471
tmagolas@rogers.com
#7 Posted : Monday, March 5, 2012 3:39:01 PM(UTC)
tmagolas@rogers.com
Hi Gene,
Water supply line is not frozen, I changed the water inlet valve and no difference. I read somewhere that the ice lifing teeth on the ice tray shold be in the up posision, if not I may need to replace the ice maker unit, dose this sound write to you?
#8 Posted : Monday, March 5, 2012 4:11:23 PM(UTC)
You did not mention it before. Yes, it is possible that the ice maker itself is the culprit. In what position are the teeth?
tmagolas@rogers.com
#9 Posted : Tuesday, March 6, 2012 8:48:22 AM(UTC)
tmagolas@rogers.com
The teeth are pushed back into the ice machine. (looks like it's ready to make ice and pop the into the bucket, but no water.
#10 Posted : Wednesday, March 7, 2012 11:23:09 AM(UTC)
Very likely the ice maker itself is bad.
- The ice maker Part number: AP3182733
Guest (6)
No water in icetray (Refrigerator & Freezer Repair)
by tmagolas@rogers.com 2/20/2012 11:16:12 AM(UTC)
2 Pages12>
