steve masters
#1 Posted : Thursday, August 9, 2007 6:51:17 AM(UTC)
steve masters
my timer is extremely slow , sometimes it show 2min left on cycle and it take 10min to finish cycle. Is it the control box or the led display panel .
#2 Posted : Thursday, August 9, 2007 10:49:18 PM(UTC)
steve masters
There are two most common things which could cause prolonged time: excessive sudsing or too much inbalance occurred. Did it show "SUD" on the display during the rinse cycle or at the end? Is your washer properly leveled? Is the washer installed on a sturdy and solid floor?
How old is your washer? If it is less then two years old then the electronic controls are under the limited manufacturer warranty.
steve masters
#3 Posted : Friday, August 10, 2007 9:32:01 AM(UTC)
steve masters
No Error On Display , Washer Is Level And On Solid Floor. Unit Is 3 Years Old . I Plan On Changing To Control Box To See It That Fixes It . Thanks Steve
Whirlpool washer timer problem (Washer Repair)
by cgaump 2/9/2012 7:09:21 PM(UTC)
Whirlpool washer timer replacement (Washer Repair)
by kurtvance 1/29/2012 5:32:08 PM(UTC)
Whirlpool Washer Timer (Washer Repair)
by kdavis93 1/15/2012 10:03:01 AM(UTC)
Whirlpool washer timer function (Washer Repair)
by Ronc11 4/9/2011 12:15:18 PM(UTC)
whirlpool washer timer stops during wash (Washer Repair)
by terryballou 1/30/2010 9:45:01 AM(UTC)
Whirlpool Washer Timer Issue (Washer Repair)
by bdrendel 12/24/2009 6:52:35 PM(UTC)
