wabi
#1 Posted : Sunday, July 26, 2009 3:19:53 PM(UTC)
wabi
I have a clunking noise in my dryer. I have repaced the front drum support and glides,but I still have the noise. I disconnected the belt and spun drum by hand and have no noise. The idler pully is in good shape. Thank you for your help. p.s. not exactly shure on the age of the dryer.
#2 Posted : Sunday, July 26, 2009 3:30:34 PM(UTC)
Pull the front panel off and check the blower wheel, might be broken or loose.
wabi
#3 Posted : Sunday, July 26, 2009 3:55:29 PM(UTC)
wabi
There is a little play there. Should that be a tight fit?
#4 Posted : Monday, July 27, 2009 12:52:51 AM(UTC)
Yes, just tighten the 3/8 screw.
Bothcoasts Handyman
#5 Posted : Monday, July 27, 2009 2:21:07 AM(UTC)
Bothcoasts Handyman
Put the belt back on the drum and motor. Spin the drum by hand again. Check and see if the noise returns if it does. It is either the belt, motor pulley or the drum.
Samsung dryer noise (Dryer Repair)
by Guest 5/31/2021 10:07:46 AM(UTC)
Dryer Noise (Dryer Repair)
by johna56 11/2/2017 1:49:28 PM(UTC)
Maytag dryer noise (Dryer Repair)
by Cmjb13 9/7/2017 7:20:37 PM(UTC)
by hitmehhh 10/7/2016 5:35:15 AM(UTC)
Plz help. affinity dryer noise. (Dryer Repair)
by JHX 4/8/2016 11:42:59 AM(UTC)
by hitmehhh 11/20/2015 5:07:53 AM(UTC)
Maytag Dryer Noise (Dryer Repair)
by azure012 7/11/2014 6:41:40 AM(UTC)
Dryer noise (Dryer Repair)
by jayjay19 1/3/2012 11:15:39 AM(UTC)
by hoan 12/30/2011 1:19:14 PM(UTC)
by Dan2175 12/21/2011 6:30:18 PM(UTC)
by wesw 11/5/2011 6:49:55 AM(UTC)
Elec Dryer Noise (Dryer Repair)
by mstickma 7/11/2011 9:12:54 AM(UTC)
by lmckelvy 11/9/2010 1:19:54 PM(UTC)
Frigidaire Gallery Dryer Noise (Dryer Repair)
by c24miller 10/15/2010 11:50:54 AM(UTC)
kenmore dryer noise (Dryer Repair)
by nobel5601 9/22/2010 1:34:49 PM(UTC)
