LailaG
#1 Posted : Wednesday, June 24, 2009 10:53:54 AM(UTC)
LailaG
The bottom oven bake burner will not light to enable baking. I can turn the knob to broil and the top broiler burner will light. The flat igniter "appears" to be getting red hot but the burner will still not light off.
Dan O.
#2 Posted : Wednesday, June 24, 2009 11:36:12 AM(UTC)
Dan O.
Quote:
The bottom oven bake burner will not light. The flat igniter "appears" to be getting red hot but the burner will still not light
Your symptom could be caused by a defective oven gas valve or a 'weak' oven ignitor. (And yes, an ignitor can glow and still be defective.)
The only way to determine for certain which is responsible is to test the amperage draw on the ignition circuit although an ignitor failure is the most common (70-80%) cause of problems in such an ignition system.
LINK > Magic Chef 34HA-2CKX-ON Oven Bake Ignitor
The ignitor on your model should draw 3.2 to 3.6 amps. Anything else and it is defective. If it is drawing within those tolerances, the oven valve would likely be most suspect.
LINK > Magic Chef 34HA-2CKX-ON Oven 'Dual' Gas Valve
You can read how such a system works at the following link:
LINK > Understanding Gas Oven Ignition Systems
JFYI
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
p.reed
#3 Posted : Sunday, July 26, 2009 12:31:51 PM(UTC)
p.reed
Bottom oven will not heat in bake mode. Broil hi & lo works fine. Igniter does not turn on in the bake mode but hear & smell gas. Although can not lite the burners with flame at top or bottom burner tubes.
Thanx,
mack
Dan O.
#4 Posted : Sunday, July 26, 2009 5:41:21 PM(UTC)
Dan O.
Than check the things mentioned for that symptom described at the 'Understanding Gas Oven Ignition Systems' link previously supplied.
Quote:
in the bake mode but hear & smell gas. Although can not lite the burners with flame at top or bottom burners.
No gas should be released without the oven ignitor glowing. I don't know where the gas you smell would be coming from. If it was through the burner, they should be able to be lit with a flame.
If you need further assistance please post the appliance's brand name and model number or even better, start a new message for your query (rather than replying to someone else's) including that product information and describe what tests have been performed so far.
JMO
Dan O.
=D~~~~~~
LailaG
#5 Posted : Monday, July 27, 2009 2:22:02 PM(UTC)
LailaG
The problem was indeed the flat igniter. Thanks so much for your help!!
Dan O.
#6 Posted : Wednesday, July 29, 2009 8:55:27 AM(UTC)
Dan O.
Quote:
The problem was indeed the igniter
Glad to hear you found the problem. Thanks for the follow up. UserPostedImage
Dan O.
=D~~~~~~
Recommend gas range single oven (General Talk)
by 007noob 6/10/2024 3:19:57 PM(UTC)
Old Hardwick Gas Range LP conversion and/or adjustment (Oven Repair (including Ranges and Cooktops))
by DaveLab 5/28/2024 2:53:48 PM(UTC)
Viking gas range oven troubleshooting (Oven Repair (including Ranges and Cooktops))
by MK_ 3/3/2024 10:10:13 AM(UTC)
Kitchenaid Gas Range KGRA806PSS00 (Oven Repair (including Ranges and Cooktops))
by bobr55 2/16/2024 1:31:09 PM(UTC)
Stuck bottom pan on gas range (Oven Repair (including Ranges and Cooktops))
by Guest 11/4/2023 12:02:07 PM(UTC)
Whirlpool Gas Range No Lights and Locked Door After Self-Clean (Oven Repair (including Ranges and Cooktops))
by Guest 2/20/2023 8:05:39 PM(UTC)
Gas Range Electrolux parts (Appliance Parts)
by becky97060 12/13/2022 11:07:33 AM(UTC)
Capri Gas Range Door won't close tightly (Oven Repair (including Ranges and Cooktops))
by Guest 5/26/2022 9:56:34 AM(UTC)
Maytag CRG7500AAW Gas Range (1995) access to spark module (Oven Repair (including Ranges and Cooktops))
by videobruce 4/10/2022 4:14:27 AM(UTC)
GE XL44 Gas Range - Oven Turns On by Itself (Oven Repair (including Ranges and Cooktops))
by keywiz77 2/27/2022 9:32:21 AM(UTC)
Gas Range - all four burners spark continuously if any one burner is lit (Oven Repair (including Ranges and Cooktops))
by eichsel 1/29/2022 7:48:44 AM(UTC)
Gas Range Burners Won't Stop Sparking (Oven Repair (including Ranges and Cooktops))
by eb5 12/7/2021 12:05:37 PM(UTC)
Samsung NX60T8711SS smart dial gas range (Oven Repair (including Ranges and Cooktops))
by bob4al 11/10/2021 2:16:51 AM(UTC)
Amana gas range turns off while baking (Oven Repair (including Ranges and Cooktops))
by Shhomemom 10/18/2021 2:11:00 PM(UTC)
Jenn-Air Cook Top Gas Range JGC1526ADS15 (Oven Repair (including Ranges and Cooktops))
by patelvi 9/15/2021 1:11:05 PM(UTC)
