Jama Beasley
#1 Posted : Thursday, July 23, 2009 3:48:26 PM(UTC)
Jama Beasley
What are the characterists of this refrigerator when the defrost heating coils go out in a high humidity area? The bottom freezer grows ice on the back wall (upper frig gets warm) and the coils seem to be frozen. I can defrost using a hair dryer, water pours into the pan, and the unit works fine again for another 5-7 days. The defrost drain pan was dry today when it frosted over again. Unplug and a quick hair dryer attack, and all is well again. I can order parts from this company, but I am not sure this is the problem. Model mfg 10-2002.
woodchuckie
#2 Posted : Thursday, July 23, 2009 5:18:26 PM(UTC)
woodchuckie
check defrost timer, defrost heater, defrost thermostat.
Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Part 12 on diagram 3 is your timer.
Replacement parts for MAYTAG PDS22LBNWW | AppliancePartsPros.com
Jama Beasley
#3 Posted : Friday, July 24, 2009 5:10:07 AM(UTC)
Jama Beasley
Thank you for taking your time to offer suggestions. We need a service repair manual and your answer helped. My husband will attempt your suggestions this weekend. We live on the ocean and the humidity seems to trigger this issue last summer and this summer, too. It NEVER happens when we can get the service company here to see the problem - so we have attempted to handle it ourselves. The hair dryer approach works "temporarily" but is not the fix or solution.
Jama Beasley
#4 Posted : Sunday, July 26, 2009 11:34:19 AM(UTC)
Jama Beasley
Thank you for the web address to the "How to..."
Under Defrost Thermostat, I was able to utilize a Multimeter and find the offending part. I went to Appliance Pros to order the part and found it called (Not a Defrost Thermostat Bi-Metal) a Thermostat Kit. There was some confusion about what to order in the name. Hopefully, this is the correct part and it will fix the problem.
Jama Beasley
#5 Posted : Sunday, July 26, 2009 11:41:51 AM(UTC)
Jama Beasley
Correction: Not Maytag bottom freezer - GE Profile PDS22LBNWW
Defrost Thermostat Bi-Metal is called Thermostat Kit which should appeat in diagram #4 (but is not shown) and listed as Item #29: Thermostat Kit, AP4009073.
