rleal79
#1 Posted : Sunday, August 3, 2008 11:54:18 AM(UTC)
rleal79
Washer is about 3 years old I have had a sleu of problems, latest is the door lock. Tried to wash a load, door will not lock, get error code od, manuel states. Washer lid must be opened, solution ( This is a safety feature. the lid must be opened before another cycle is started) I have opened the door, closed the door unplugged the washer, turned it on turned it of. Nothing seems to help. This occurred once before the lid was not going all of the way back when it was opened, door was resting on a top cabnette. Pulled out washer away so door wood open without resting on top cabnette. This worked for several months until today same problem showed up, i tried same thing with no luck I have read all of the past bloggs all 110 pages. I did not see anyone else with the same problem on a maytag. Any help will be greatly appreciated.
Thanks Rod
Aimeet2066
#2 Posted : Sunday, July 26, 2009 7:25:44 AM(UTC)
Aimeet2066
Thanks Rod
What did you do?
sidfink43
#3 Posted : Sunday, July 26, 2009 10:54:08 AM(UTC)
sidfink43
Hi Aimee
Would you post your complete model number so we know exactly which machine we are dealing with.
wburns29
#4 Posted : Sunday, July 26, 2009 1:02:01 PM(UTC)
wburns29
i have an Kenmore Elite HE 5t and I get the error codr F22. The door will not open. What can I do?
sidfink43
#5 Posted : Sunday, July 26, 2009 2:36:50 PM(UTC)
sidfink43
Please start a new post with your full model number, and a detailed description of your history with the machine, how it was operating up until the problem and whether or not you have opend the door and what happens if you start it up again.
In the meantime, if you have not unlocked it you can take off the lower front panel and reach up to the door lock assembly. You should find a small tab. Pull down gently and it should release the door.
Then, unplug the machine and try it again the following day and see if it does the same thing. You should also find a tech sheet inside the panel which may allow you to place it in test mode and to go through troubleshooting.
Aimeet2066
#6 Posted : Monday, July 27, 2009 6:49:22 PM(UTC)
Aimeet2066
Originally Posted by: sidfink43 Go to Quoted Post
Hi Aimee
It's a
Maytag Neptune
FAV6800AWW
We think it is the switch that is under the top. It is like a $75 part for 1 side.
sidfink43
#7 Posted : Tuesday, July 28, 2009 1:02:38 PM(UTC)
sidfink43
Hi Aimee
It sounds like the lid switch, but as you know there are two of them on your machine. The cost from this site (no I do not work for them) is a little less than your earlier post.
See if you cannot tell if the switch is engaging by using a magnet and listening for a click, or using a magnet and meter to test continuity.
Here is a service manual for your machine.
http://www.servicematters.com/m...ibrary/docs/16022808.pdf
Good luck
Guest (6)
Whirlpool slams door lock on/off during baking, then cooling (Oven Repair (including Ranges and Cooktops))
by 34Ford 9/29/2022 3:27:58 PM(UTC)
GE WCVH6800J0MS door lock DIY repair? (Washer Repair)
by TimBlock 4/10/2022 3:53:57 PM(UTC)
Washer showing voltage on all three door lock leads (Washer Repair)
by metalman33 11/6/2021 11:49:11 AM(UTC)
Oven Door Locked - No Power (Oven Repair (including Ranges and Cooktops))
by Nothing Finer 10/26/2020 3:33:54 PM(UTC)
Oven fan won’t stop/door locked/ F3 error (Oven Repair (including Ranges and Cooktops))
by Lizete 10/9/2020 7:53:38 AM(UTC)
Maytag Neptune (Front Loading) Washer Door Locked (Washer Repair)
by frjosephklee 5/4/2020 9:03:35 AM(UTC)
Kitchenaid wall oven door locked (Oven Repair (including Ranges and Cooktops))
by mdawley 3/6/2020 9:40:01 AM(UTC)
Whirlpool Wall Oven Door Locked and No Power (Oven Repair (including Ranges and Cooktops))
by sunia 11/14/2019 7:10:53 AM(UTC)
maytag mgs5752bds gas range door lock (Oven Repair (including Ranges and Cooktops))
by bmcd47 12/19/2018 7:33:43 AM(UTC)
whirlpool front load won't run door locked won't open. (Washer Repair)
by bob67 12/6/2018 3:54:59 PM(UTC)
electronic door lock not activating (Washer Repair)
by cleetuor 10/27/2018 7:47:25 AM(UTC)
Whirlpool Double Wall Oven Dead after Self Clean - Door Locked (Oven Repair (including Ranges and Cooktops))
by cmartin27 1/19/2018 1:24:46 PM(UTC)
Oven door lock (Oven Repair (including Ranges and Cooktops))
by von.ahouse@hotmail.com 10/29/2017 8:46:57 AM(UTC)
Replacement Door Lock Wiring (Washer Repair)
by cjohns62 7/27/2017 10:06:28 AM(UTC)
Whirlpool Accubake Double Oven Lower Oven Door Locked (Oven Repair (including Ranges and Cooktops))
by Malexi 6/2/2017 9:46:25 AM(UTC)
