jsbinptc
#1 Posted : Friday, July 24, 2009 11:00:11 AM(UTC)
jsbinptc
I had a frost encased freezer. I chipped out the frost and in doing so , must have harmed the cooling coil. After I was done there was a slight hissing noise like escapping gas and then over the last 48 hours the unit has lost all its cooling.
Can I repair this? Do I replace the cooling unit?
Any help will be appreciated.
Jim
#2 Posted : Friday, July 24, 2009 11:37:13 AM(UTC)
Leaving it plugged in caused the compressor to suck in moisture, thus damaging the internal surfaces of the compressor=new compressor time.
jsbinptc
#3 Posted : Friday, July 24, 2009 12:59:47 PM(UTC)
jsbinptc
Is this repairable? If so, do you sell the parts.
Thanks.
#4 Posted : Friday, July 24, 2009 3:24:06 PM(UTC)
You need a new evaporator, compressor and dryer=about $600 including labor.
