rbs1324
#1 Posted : Wednesday, July 22, 2009 8:03:31 PM(UTC)
rbs1324
Washer fills with water and then agitates and drains correctly, but it does not continue on to the Rinse Cycle. Any ideas what may be causing this? If I push the selector in and turn to Spin Cycle and pull out selector it will spin, just won't do anything at the Rinse Cycle.
Thanks for any help
#2 Posted : Thursday, July 23, 2009 2:14:50 PM(UTC)
Check if the washer is getting cold water (choose cold water on the water temperature switch).
Open the control panel and look for the tech sheet. Perform the troubleshooting as described there.
rbs1324
#3 Posted : Friday, July 24, 2009 10:23:38 AM(UTC)
rbs1324
No, it's not getting cold water. It doesn't matter what setting I put the temp switch to either.
#4 Posted : Friday, July 24, 2009 12:29:17 PM(UTC)
Did you find the tech sheet?
maytag washer no rinse cycle (Washer Repair)
by obxracer#3 11/5/2012 6:15:14 PM(UTC)
Washer, no rinse cycle (Washer Repair)
by Bob21 1/23/2012 4:45:25 AM(UTC)
amana front loader no rinse cycle (Washer Repair)
by waynes91 1/14/2012 1:13:14 PM(UTC)
No Rinse cycle (Washer Repair)
by lilhonie43 8/25/2011 2:39:08 PM(UTC)
No cold water and no rinse cycle (Dishwasher Repair)
by jhead 2/22/2010 4:24:19 AM(UTC)
No Rinse Cycle (Washer Repair)
by dino062959 2/12/2010 1:15:58 PM(UTC)
No rinse cycle (Washer Repair)
by bender 11/25/2008 6:35:58 PM(UTC)
