2 Pages<12
mpower36
#11 Posted : Thursday, July 23, 2009 3:10:06 PM(UTC)
mpower36
Oven had been on for 40 minutes when it started beeping. All burners had F5 01 and the oven display read F20. Pressed Stop/Clear but no use. Had to turn off the breaker to get it to stop. When breaker was turned back on, everything was fine. Started cooking on stove top and after 10 minutes, errors were back.
I saw another post from ludmilaz (F5 00 or F5 01 error code) that was very similar and noticed the author said that the transformer in the apartment complex had just been replaced. I passed line workers cutting trees near my house right before this happened.
Does this happen frequently to this model? What diagnostics can I do?
mpower36
#12 Posted : Thursday, July 23, 2009 3:12:04 PM(UTC)
mpower36
#13 Posted : Thursday, July 23, 2009 4:35:11 PM(UTC)
You referred to the previous post with very similar issue. Just perform the same troubleshooting and post the results. If you need the correct part numbers then post the complete model number of the range. Try not to duplicate your posts. It does not do any good for you and for us.
mpower36
#14 Posted : Thursday, July 23, 2009 4:51:47 PM(UTC)
mpower36
Okay. Checked the harness that connects the UIB, the EOC, and the Power board. Connection to the EOC seems a little loose. Tried again and could operate the oven, but not the burners. Unplugged and wiggled harness. Tried again, all errors are back and can't use burners or oven.
I have that the following part numbers for Model 790.99123408
316418750 EOC
316271801 UIB
316272402 Power board
I read somewhere that it may not be good to replace a single board because Frigidaire came out with upgraded boards that don't play well with the old ones. Know anything about this?
Thanks.
#15 Posted : Thursday, July 23, 2009 5:00:18 PM(UTC)
This is something new to me but I don see why you can not do it.
2 Pages<12
