mike dapson
#1 Posted : Wednesday, July 22, 2009 5:22:11 PM(UTC)
mike dapson
loud clunking when changing cycles,is it the transmission?? is this machine direct drive??is it gear case..trans neutral drain?? or bottom pinion gear case??any suggestions?? & or other parts to put in it while apart?thanks mike
mike dapson
#2 Posted : Thursday, July 23, 2009 11:04:14 AM(UTC)
mike dapson
also getting a rim of grease (bearing?)around tub when load is finisher..is there a braring going?? part of gearbox?
mike dapson
#3 Posted : Thursday, July 23, 2009 11:04:58 AM(UTC)
mike dapson
the washer is 6 years old
#4 Posted : Friday, July 24, 2009 12:18:20 PM(UTC)
You have a bad tranny, AP3096209, relatively easy to replace.
