timjmix11
#1 Posted : Thursday, July 23, 2009 5:29:50 AM(UTC)
timjmix11
There is no water being sent to the ice cube tray in ice maker. Is there a timer or pump I can check? Water lines are clear of debris.
woodchuckie
#2 Posted : Thursday, July 23, 2009 5:47:41 AM(UTC)
woodchuckie
Is there ice in the mold now. Will it dump the ice when you manually add water and let it freeze.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze, blocking the fill tube. You can take the water line off the valve and watch to see if it drips.
timjmix11
#3 Posted : Thursday, July 23, 2009 8:25:59 AM(UTC)
timjmix11
oops! please check next message
timjmix11
#4 Posted : Thursday, July 23, 2009 8:52:54 AM(UTC)
timjmix11
I switched the wires and the water went into the mold so I guess the valve works. What sends the signal to the valve and how can I check that?
No Water To Icemaker But Door Water Works (Refrigerator & Freezer Repair)
by m cox 6/25/2015 10:54:33 AM(UTC)
No Water to Icemaker (Refrigerator & Freezer Repair)
by islandbeachsp 9/26/2012 1:05:29 PM(UTC)
No water to icemaker and dispenser (Refrigerator & Freezer Repair)
by thistle4celtic1 7/22/2012 10:29:01 AM(UTC)
by ewatt 9/23/2011 7:56:23 AM(UTC)
no water to icemaker (Refrigerator & Freezer Repair)
by Sallie H 6/15/2009 12:53:04 PM(UTC)
No water to icemaker, water dispenser works (Refrigerator & Freezer Repair)
by BobK898 1/7/2009 10:08:20 AM(UTC)
