dave.c
#1 Posted : Tuesday, July 21, 2009 5:09:17 PM(UTC)
dave.c
Seven year old Frigidaire side by side will not cool. Approx. 2 weeks ago, it went stopped working & we had the relay replaced. The frig worked again for one week, and then stopped (the night it stopped we had a series of low power flashes, about every 5 minutes for maybe 3 hours). I was told it needed a new cold control & defrost timer unit so I replaced this part today, but still no go. The fan is on in the freezer section, interior lights work, but the compressor & compressor fan are not working. Any assistance appreciated. Thanks!
#2 Posted : Wednesday, July 22, 2009 3:25:03 AM(UTC)
You probably have a blown adaptive defrost pc board behind the control panel. AP3214257. If bad, would be a good idea to put a 1000 joule surge protector on the fridg outlet, just make sure it's one for refrigerators.
dave.c
#3 Posted : Wednesday, July 22, 2009 11:59:35 AM(UTC)
dave.c
Thanks richappy. I believe I replaced the part you refer to. In the schematic, it was described as: "control -defrost, adaptive Timer, pc board". It's listed as part# 240545403 on the Frigidaire website, but I was provided with an updated part # 240554502. It is described on my bill simply as a "defrost timer". Did I replace the wrong part? I cannot locate the number you provided (AP3214257). Also, I notice now that there is a bit of insulation near the compressor that has been shredded or melted. Have never noted compressor to be hot however. Thanks again for your advice.
#4 Posted : Wednesday, July 22, 2009 1:20:38 PM(UTC)
That's the right part, an updated one that hopefully will be more reliable.
refrig will not cool and freezer will not freeze (Refrigerator & Freezer Repair)
by marykiefer 2/10/2013 4:44:35 PM(UTC)
