2 Pages<12
ericsaraw
#11 Posted : Wednesday, July 22, 2009 7:31:38 AM(UTC)
ericsaraw
I thought you said in your previous post that the pump was OK. I'm a little confused.
Thanks, Eric
misterfixall
#12 Posted : Wednesday, July 22, 2009 9:12:10 AM(UTC)
misterfixall
all i know is that i replaced the pump+ the problem resolved itself
carris69
#13 Posted : Monday, August 9, 2010 4:27:34 PM(UTC)
carris69
im getting the fh code and no water is going in the machine it just throws up the code after a few mins of no water ive replaced the inlet valves it didnt help ive recently replaced the pump before this problem came along do you think its the ccu im tired of spending money on this thing its only 2 yrs old
ggdave
#14 Posted : Wednesday, November 10, 2010 9:32:12 AM(UTC)
ggdave
fh code can be caused by a dirty airtrap. small part back of tub near bottom. it is some what opaque, if it looks dirty, it probably is. can be replaced or cleaned by using vinegar or pool acid. use a plastic pail mix pool acid and water (not very much, just enough to cover part) drop in part walk away for an hour. use gloves to remove part rinse, use a bottle brush if necessary and reinstall. neutralize acid by diluting with water and adding a little baking soda before dumping into a toilet or sink. pool acid will eat metal, concrete, your skin, etc.
Airtrap has a tube that attaches it to the flow control, if it is clogged, air pressure can not be created, and it is what the sensor uses to tell the control unit if water is indeed entering machine.
this part is never mentioned in troubleshooting.
Guest
#15 Posted : Tuesday, June 1, 2021 3:52:32 PM(UTC)
Guest
Rank: Guest
United States
I have a duet ht frontload. It will get to about 12 minutes into a cycle with water in. Then it will flash an fh code and drain.
Guest
#16 Posted : Tuesday, June 1, 2021 3:53:51 PM(UTC)
Guest
Rank: Guest
United States
Guest (4)
Whirlpool duet error code FH (Washer Repair)
by Ben rodriguez 4/15/2013 6:15:13 PM(UTC)
whirlpool duet error code FH (Washer Repair)
by misterfixall 1/11/2009 10:36:01 AM(UTC)
2 Pages<12
