mani
#1 Posted : Wednesday, July 15, 2009 2:21:13 PM(UTC)
mani
when i turned it on ,it take water after taking a water it did not do anything just display f/h error massage.i checked drain pump it works fine,its drain very good.can someone help me about it?
#2 Posted : Wednesday, July 15, 2009 7:27:16 PM(UTC)
Most likely the problem is a bad water level pressure switch (#23 on the diagram).
- The water level pressure switch Part number: AP3128700
mani
#3 Posted : Tuesday, July 21, 2009 4:31:23 PM(UTC)
mani
i replace water inlet valve and also replace pressure switch but it still give me f/h error message.i check the water line this is also clear.i also change the pressure switch tube what could be with my washer?.tell i see the sensor on the water line close to soap dispencer ,what it does?
whirpool duet show error msg( FH) (Washer Repair)
by mani 7/21/2009 6:42:24 PM(UTC)
