when i turned it on ,it take water after taking a water it did not do anything just display f/h error massage.i checked drain pump it works fine,its drain very good.can someone help me about it?
i replace water inlet valve and also replace pressure switch but it still give me f/h error message.i check the water line this is also clear.i also change the pressure switch tube what could be with my washer?.tell i see the sensor on the water line close to soap dispencer ,what it does?
