joex
#1 Posted : Saturday, December 29, 2007 8:32:58 AM(UTC)
joex
The dryer works but the timer goes in reverse. Do I have to replace the timer?
misterfixall
#2 Posted : Saturday, December 29, 2007 8:40:51 AM(UTC)
misterfixall
are you saying timer turns counter clockwise? right to left? how does the dryer behave other than that?
joex
#3 Posted : Saturday, December 29, 2007 8:52:12 AM(UTC)
joex
Yes, the timer turns counter clockwise. This occurs in the auto dry cycle. The dryer will dry but since it goes in reverse the time is shortened. Not sure what happens in the other cycles.
#4 Posted : Saturday, December 29, 2007 12:18:35 PM(UTC)
You probably have a black plastic housing on your timer and the timer motor screws on the back of it. There is a motor mounted non the gear train, that has been polled to run backward, you will need to replace it. Unfortunately they do not sell it, need to buy a new timer unless you can get one used. Most timer motors of the age dryer where the same and turned the same direction.
joex
#5 Posted : Sunday, January 6, 2008 6:11:30 PM(UTC)
joex
thanks for your help. I replaced the timer and it is now working.
