larsonwells
#1 Posted : Saturday, January 5, 2008 5:49:22 PM(UTC)
larsonwells
Purchased new handle part #1801
Managed to get interior "choke cover" (part #1804) removed from door with minimal tab damage
This gives open access to top screw of door handle, bottom screw is hidden within door assembly (part #1800 on diagram)
Is there a simple trick to separate the inner steel door section from the outer plastic/glass part? I can pry the plastic tabbed areas away from the metal door section 1 or 2 or even 3 at a time (with a helper) - but the parts do not seem inclined to separate.
#2 Posted : Sunday, January 6, 2008 4:13:18 PM(UTC)
Try to remove the latch/spring assembly (#1810 on the door break down diagram).
Good luck.
Replace door handle (Microwave Repair)
by thunderbolt 9/2/2011 6:22:51 PM(UTC)
ge microwave jvm1740dmww1 process to replace door handle (Microwave Repair)
by DSG 6/15/2011 5:13:14 AM(UTC)
Dismantle and replace door handle (Refrigerator & Freezer Repair)
by stemwinder 3/6/2010 2:11:56 PM(UTC)
GH9176XMS1 Replace Door Handle (Microwave Repair)
by ron305 2/15/2010 9:01:24 PM(UTC)
by Napoleon 7/22/2009 6:58:49 AM(UTC)
by madoian 3/29/2009 8:41:03 AM(UTC)
axxis dryer - how do I replace door handle (Dryer Repair)
by christykarsten 5/6/2008 6:58:23 AM(UTC)
by btcsys 11/9/2007 12:36:51 PM(UTC)
